Wiper/Directional Problem
Old May 15, 2011 | 07:57 PM
guitarfule's Avatar
guitarfule
Default Wiper/Directional Problem
I have 2006 Ram 1500. Was driving the other day in the rain and the wipers stopped working so i signaled to pull over and the directional did not work either. I sat there for a few minutes and was going to check the fuses and all of a sudden it all worked again. Was hoping someone else had this problem and already knows the solution. Please help.
Old May 15, 2011 | 08:36 PM
BigD's Ram's Avatar
BigD's Ram
my wipers well go really slow when i have them all the way on fast they have never stopped workin and with the turns signals sometimes i will turn my left signal on and my right signal will come on i have no idea what the problem is so hopefully someone can post something
Old May 16, 2011 | 08:35 PM
lxman1's Avatar
lxman1
Site Moderator
I would suspect the multifunction switch in the column.
Old May 16, 2011 | 10:29 PM
Denniss66's Avatar
Denniss66
i have had this problem too and still do i think it has to do with the wiper switch but im not sure but when i signal left and it signals right i just tilt my steering wheel up and down and it works normal again must be a bad connection with the plugs or something never took my column apart to try and pin point it out
Old May 16, 2011 | 11:59 PM
Geezir's Avatar
Geezir
Multifunction lever seems to be a weak point in these trucks.
My '05 wipers act up and the signals sometimes reverse. Wipers on my bosses '05 act up as well.
I've heard from a few sources that the culprit is the lever itself.
Old May 17, 2011 | 12:44 AM
Cthulhu's Avatar
Cthulhu
The multifunction switch has been identified in the ~2006 model years... I had mine switched last year when it decided it no longer wanted to signal the direction I tried.. Nothing like driving down the interstate, signaling left, while intending to go right... with a 20 ft travel trailer in tow... There is a recall "if there is a problem"... not sure how they got away with that.
The Dodge dealer was happy to oblige the replacement though.
Old May 17, 2011 | 09:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sounds to me like the switch also but I would make sure i could replicate it a few times to be sure
