Strange Start-up
Old May 22, 2011 | 10:30 PM
NSASarge's Avatar
NSASarge
Default Strange Start-up
Went to start my 08 5.7 Hemi this evening. It acted like it was flooded. (Zat possible?) Anyway, I was told to put my foot to the floor and try to start it that way. Well, It simply cranked away without starting. When I released the key, it kept cranking! I had to turn the key off to stop it from cranking! After this, it started normally. Can someone explain this? OR, was this just some wierd incident?
"SARGE"
Old May 23, 2011 | 06:50 AM
MikeHTally's Avatar
MikeHTally
I believe that year was the beginning of "bump start" where the key-turn is only telling the computer to turn the starter. As for holding down the loud pedal, I suspect the TPS was not allowing it to start (?).
Did it ever start?
Old May 23, 2011 | 08:41 AM
bwheelersc's Avatar
bwheelersc
My 2007 does that every once in awhile. You don't have to hold the key for the motor to keep cranking. Mine (once every 4 months) will crank for 10 seconds before it finally cranks up.
Old May 23, 2011 | 01:20 PM
NSASarge's Avatar
NSASarge
Yes. As I stated, after this incident, it started and ran normally. No problems since.
Old May 23, 2011 | 03:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would not get concerned unless it did it often. We went to PCB 2 weekend ago in the wifes Mini and as Im driving I lost all IC gauges. The wife freaked but I put it in N, cut it out and restarted it, put it back in D and kept going. Thats the first time it has ever done that and hasnt done it since
Old May 23, 2011 | 04:01 PM
Razorhawg's Avatar
Razorhawg
my 07 has the tip start you just bump the key and it starts
should say XBNP Tip Start on your build sheet
Old May 23, 2011 | 04:36 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ Good to know right there
