Thermostat/Cooling
Old May 26, 2011 | 11:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
That is a nice setup Hammer
Old May 27, 2011 | 02:32 PM
hornshemi's Avatar
hornshemi
Default 2005 Ram 1500 5.7 Hemi
Hey,
I have just rolled my truck over 80,000 kms which is approx 49000miles. I have replaced the factory deck and run one 10" sub, serviced my tranny, converted the engine to full synthetic, flow pro muffler dumping at the rear axle, new brakes and tune up. I was heading to the cabin may long and the line up out of town was thirty minutes. With all the stop and go my temp gauge started to rise to 3/4!!! and rising. I cranked the heat in the cab and it balanced out. Once I hit the highway I was fine but now when I drive the city I notice the temp still elevates with idling too long.
Any insite on this issue would be much appreciated.
Old May 27, 2011 | 04:02 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by hornshemi
Hey,
Bad clutch fan, low coolant, worn-out coolant, air in the line, blockage all could cause the issue...
Old May 27, 2011 | 08:46 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, I'm betting the fan clutch is going south.
Old May 28, 2011 | 09:06 AM
MikeHTally's Avatar
MikeHTally
With the motor warmed up (but off), can you turn the fan by hand? It should be difficult, if not impossible. I suspect you'll be able to turn the fan fairly easily. If so, it's time for a clutch or an e-fan.
