Thermostat/Cooling
Old May 25, 2011 | 06:17 PM
jones.aaron88's Avatar
jones.aaron88
Question Thermostat/Cooling
I want to install a thermostat that operates at a 165 degrees. Will this hurt my engine or help it run smoother? I also want to put a electric fan to replace the big metal fan to gain some horse power. Will this help gain or not? And if so what brand should I get. I have a 2003 Ram 1500 5.9L?
Old May 25, 2011 | 06:25 PM
lxman1's Avatar
lxman1
Site Moderator
You will gain poorer gas mileage and probably sludge from running the engine too cold.
The e-fan will free up a few hp.
Old May 25, 2011 | 06:28 PM
MikeHTally's Avatar
MikeHTally
What he said. That's too cold for a street motor.
Old May 25, 2011 | 06:39 PM
jones.aaron88
Thanks guys what is the coldest I can run my enigne?
Old May 25, 2011 | 06:40 PM
jones.aaron88
Also I would like to install a dual e fan. What brand do you suggest?
Old May 25, 2011 | 06:56 PM
HammerZ71's Avatar
HammerZ71
180* is the lowest you should go in a thermostat.
JasonW has a very nice dual fan setup on his 2nd Gen Ram (which is basically what your drive train is a holdover from.
He's got a thread in 2nd Gen of PM him for pics and specs...
Old May 26, 2011 | 09:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
In the defense of stats, I know a guy or two that run 170* stats. Chefred is one of them I think. Sawcut64 might be another.
A lot of us use Ford Taurus e-fans and Hayden fan controllers also. We have the fan info and stat info all in the FAQs at the top of this section and linked below in my signature. Be sure to check it out and more
Old May 26, 2011 | 04:01 PM
HammerZ71's Avatar
HammerZ71
Chefred has BIG TIME mods, I wouldn't go that low unless I was doing a truck for the strips...
Here's JasonW's setup on his 2nd Gen with 5.9 engine:
9A maximum draw per fan, 6000 CFM mounted on a professional looking shroud.
Total spent was about $450 if you count the wires and connectors.
These ain't no "junkyard" fans, LOL...
Old May 26, 2011 | 10:06 PM
jones.aaron88
thanks guys. y'all are great, and thanks again for the help
Old May 26, 2011 | 10:52 PM
lxman1's Avatar
lxman1
Site Moderator
I have a pair of those cheap 14" fans, just like those. I may make me a sheet metal shroud one day.
