Steering pop and grind on right turn?
Old May 28, 2011 | 08:12 PM
lungman's Avatar
lungman
Default Steering pop and grind on right turn?
I need a little help guys. I have an 03 4x4 with 145000k that's been well taken care of but is now bleeding me. In the last 12 months I have changed alot of front suspension and brake parts. All the suspension parts are Moog and consist of all new ball joints and control arms, inner and outer tie rods, monroe reflex shocks, new calipers and hawk pads with PS rotors.
Now I have a new pop when the thing sets on the ground, if you turn the wheel side to side you get a pronounced pop. I notice it while driving,mostly on right hand turns. It will also occasionally groan or grind while accelerating in a RH turn.
Any ideas will be appreciated!
Old May 28, 2011 | 11:11 PM
Big_Wheel's Avatar
Big_Wheel
check your cv shaft..since everything else is new
Old May 29, 2011 | 07:19 PM
lungman's Avatar
lungman
Got under there and gave both a shake and they both had a lot of play? Is that an indication they need replaced. Everything else is nice and tight. I did notice the new upper ball joint on the driver side is giving up a lot of grease, maybe I over filled him.
Old May 29, 2011 | 07:55 PM
lungman's Avatar
lungman
I searched on DF for methods of changing the CV and found a lot of guys having trouble. here is a link a found on the net thats pretty cool and shows an 04 cv change.
http://www.youtube.com/watch?v=qikJtYeG8x4
Old Jun 1, 2011 | 04:13 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know you got under there but maybe you should get under there while someone else turns the wheels back and forth to help find the noise??
Old Jun 2, 2011 | 12:22 PM
lungman's Avatar
lungman
Thanks weed but i tried that. I couldn't narrow it down. When i shook the CV it sounded similar to the pop I am hearing when they turn the wheel. The grind on the turn was getting worse so I ordered the CVs which should be hear today. Cost me 125 with shipping so it won't kill me to change and see. Plan on putting them on tomorrow and i'll post if that was the fix or not.
I'm still up for any ideas though, if this doesn't work I don't know where to go next?
Old Jun 3, 2011 | 05:31 AM
JeffBea's Avatar
JeffBea
I'm having a simular problem, please post back when after you replace cv joints. Thanks
Old Jun 5, 2011 | 07:14 PM
lungman's Avatar
lungman
Well I tore into the front end today. Getting the CVs off is not as easy as the video shows, unless you have a lift to get the leverage you need to pull it away from the pumpkin enough to free it up. I ended up freeing the knuckle from the upper control arm and it came away easy from then on. After doing this I noticed the wheel bearing assembly was too sloppy and pulled it off(took about an hour of heat, hammering, and cussing to break the rust loose) while I had the CV out of the way. Got Timkens from autozone for 175.00 each, ouch.
After test drive everything sounds and feels good, if I had to pick which one of the two caused the problem I would say it was more the WB assembly than the CV, but both were shot. Now everything is replaced with parts I believe are better than stock, which I managed to get 100K with.
Hope this helps.
Old Jun 5, 2011 | 07:33 PM
lungman's Avatar
lungman
Another bit of info. The WB assemblies are 134.00 each at rock auto with shipping included, I paid 185.00 each with tax today at auto zone, 100.00 bucks pissed away cause I didn't order them when I ordered the CVs.
Old Jun 5, 2011 | 07:58 PM
lxman1's Avatar
lxman1
Site Moderator
Been a rash of bearing failures lately. Both of mine failed in less than 45K miles.
