Help!! 05 Ram 1500 Overheating at Idle
Old Jun 2, 2011 | 08:13 PM
engine7's Avatar
engine7
Default Help!! 05 Ram 1500 Overheating at Idle
Searched the forums for an answer but didnt come up with much. My 05 Ram 1500 is running hot at idle, has given me the check guages light and beep. Cools off while driving to the normal range. Upper and lower Radiator hoses are hot .. I dont understand what is going on.. Any ideas??
Old Jun 3, 2011 | 12:08 AM
lxman1's Avatar
lxman1
Site Moderator
Sounds like your fan clutch may be shot and it is not speeding up the fan enough to pull enough air thru the radiator. What engine to you have?
Oh, and welcome to the forum.
Old Jun 3, 2011 | 09:03 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed. need to know engine size though.
If both upper and lower rad hoses are hot, the stat has to be open, the pump has to be circulating and the rad isnt blocked.
Old Jun 3, 2011 | 09:17 AM
engine7's Avatar
engine7
sorry its the 4.7 V8 ... Thanks for the help so far
Old Jun 3, 2011 | 09:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check around the site a bit but most guys with 4.7s that over heat end up with blown head gaskets and/or cracked heads. Keep that in mind when going through your diagnostics.
Old Jun 3, 2011 | 06:44 PM
RAM_IT_07's Avatar
RAM_IT_07
First off what is hot ????? If its only while sitting jus like these guys said your not getting enough air flow through the radiator , either the fan clutch , poor circlation ect
Old Jun 3, 2011 | 08:17 PM
engine7's Avatar
engine7
Temp guage goes from 3/4 to the red line with the check guages light on. Is there a way to trouble shoot the fan clutch? Sould I be able to spin the fan by hand with the engine turned off? Thanks for the help so far.
Old Jun 3, 2011 | 09:30 PM
xjfever's Avatar
xjfever
Are you losing any coolant? If not the fan clutch is likely the problem, if so I would check the oil for coolant contamination. You can do a coolant pressure test also to check for blown head gaskets. Usually though overheating in traffic or at idle is a low airflow problem like stated previously. Overheating at speed is usually indicative of a low coolant flow problem.
Old Jun 3, 2011 | 09:45 PM
RAM_IT_07's Avatar
RAM_IT_07
Elec fans ??????
Old Jun 3, 2011 | 10:42 PM
HammerZ71's Avatar
HammerZ71
If you've had it hot enough for a CEL in a 4.7 you've probably done in the head gasket, maybe cracked a head. The 4.7 has those coolant lines VERY close to the cylinder walls - too close IMO.
Don't operate that truck until you diagnose the problem, but yeah if it's coming back down to normal temp when moving and getting air thru the fins, then in all probability the problem is with the clutch fan...
