3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Dot 4 exceeds specs of dot 3, so dot 4 is better! nice easy upgrade...mixing is not a problem, but if your old fluid is really bad maybe a flush would be better than mixing bad/new.
What he said.
I've just done this last month and flushed the whole system with Dot4 when I put new calipers on my 03 QC Hemi.
No problems with this upgrade.
Remember, bleed the system starting with the rear caliper furthest away from the master cylinder and work forward, ie: Rear passenger-rear driver-front passenger-front driver.
Al.
