Are all dealerships full of $hit
Old Jun 7, 2011 | 09:05 PM
RAM_IT_07's Avatar
RAM_IT_07
Default Are all dealerships full of $hit
Ok so i got the truck to the stealership this morning, they ran the scanner and told me i do ha e a cat code but its because i have a aftermarket 02 sencor wtf!!!!!!!!!!!! They say you can only use oem 02 sencors on the hemi .. So i kindly told them tbey were full of it and brought the truck sum where else !!!!! Correct me if im wrong but dont tbe 02 have a seperate code for them ????? And cant you run after market bosh o2s ??????
Old Jun 7, 2011 | 09:37 PM
bgbluram2's Avatar
bgbluram2
Did they tell you that you have a tire code too because you can only run factory Goodyears on your truck?
That doesn't make any sense. You may indeed have an 02 sensor code, however, it is likely due to something other than the brand of the 02 sensor. For instance, wrong part number, bad 02 sensor, burning oil and fouling the 02 sensor, rat ate the wires on the 02 sensor.... you get the idea.
Google Chrysler CEL codes and you can view an entire list of engine codes and compare to the code that you have. The lists usually show what the code pertains to such as: P0308 = misfire, cylinder 8
Old Jun 7, 2011 | 09:46 PM
Matt99's Avatar
Matt99
They are very particular to OEM O2 sensors....but they sjould have their own cod
My truck got hung wide open at 60mph+ and they said it was due to my aftermarket CAI
Old Jun 7, 2011 | 09:51 PM
bgbluram2's Avatar
bgbluram2
Haha, I love people who speculate when they don't know what the hell they are talking about, or who they are talking to for that matter.
Old Jun 7, 2011 | 10:18 PM
Ben D.'s Avatar
Ben D.
I'd put money on the OEM ones are made by bosch... spark plugs on the newer trucks are bosch OEM.. at least in my 4.7 it's that way.
Old Jun 7, 2011 | 10:45 PM
HammerZ71's Avatar
HammerZ71
Bosch O2s don't work in Rams, or at least on '04 & '06 Hemis, know those two for a fact...
Actually, you can add the '03 as well:
https://dodgeforum.com/forum/1806499-post9.html
I think it's a voltage issue because I know most widebands don't work plugged in their as well...
Old Jun 8, 2011 | 12:22 AM
T-Muns's Avatar
T-Muns
You know, when I did my swap to 03 hemi, I used brand new Bosch O2s. I had a code for the upstream right away but figured it might be an issue with the re-wiring. Replaced it with a new NGK and blamo, no code.
Old Jun 8, 2011 | 08:30 AM
RAM_IT_07's Avatar
RAM_IT_07
Im really starting to miss my rcsb 5,9 you couldnt kill that truck
Old Jun 8, 2011 | 09:07 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hammer and Ben D - I just bought and replaced my front two O2s with some from Autozone. The P/N was 15504 and they are $25 each. To my surprise when I opened then box they had mopar part numbers on the bad. I can take a pic if needed. I put them on last week and had had no issues.
Old Jun 8, 2011 | 01:31 PM
RAM_IT_07's Avatar
RAM_IT_07
Does anyone now the 02 sencor code im tired of going back and forth with the dealer !!!!! They keep saying its the 02s making the cat code pop up but i still think its b/s !!!!!!!!!!! They just replaced the cats and thats all the can say wtf
