HOW TO????: 2004 Ram 4.7L auto to manual conversion
Old Jun 7, 2011 | 11:27 PM
heavyhalfer22's Avatar
heavyhalfer22
Default HOW TO????: 2004 Ram 4.7L auto to manual conversion
Well as the title states i have a 2004 half ton ram with a 4.7 motor auto trans. Im wondering what all i will need to do a full conversion to a 5 speed manual
Old Jun 8, 2011 | 01:51 AM
jasonw's Avatar
jasonw
Site Moderator
I will move this to the 3rd Gen section for you.
Old Jun 8, 2011 | 02:48 AM
Bigboytoys's Avatar
Bigboytoys
I did a auto to manual conversion on my 'stang, but not entirely sure about the Ram, since mine was factory 5 speed...but to give you an idea of things at least needed....
1.)5 speed pedal cluster
2.)flywheel
3.)Clutch
4.)Pilot bearing and throwout bearing
5.)Shifter
6.)Clutch cable/Master cylinder,slave cylinder? (Are Rams hydro or cable systems?)
7.)Transmission
8.)Drive shaft/output shaft yoke? (I know on the 'stang the yoke was a different size, was easy to swap...If you need to, might just be easier to find a 5 speed shaft.)
9.)Tuner to tune PCM to knock out auto functions
As I said, this was all pertaining to the stang, so it may or may not apply, but it should give you a general idea of what is needed. Just make sure you have everything before starting it, and it will go smoothly. To give you an idea, it took me and a buddy a full day to convert the 'stang.
Old Jun 8, 2011 | 06:52 AM
MikeHTally's Avatar
MikeHTally
Sounds like it's time for another radiator-cap upgrade.
Old Jun 8, 2011 | 09:44 PM
heavyhalfer22
thanks BBT. Rams are hydro clutches, atleast in 3rd gen. That list helps a little it probably wont be much different in the truck vehicles at their basics are the same, i prob. will just drop a junkyard motor from a rolling 5 speed chassis from Collis 4x4's junk yard they think they have one. That will be complete with the ecm and everything so i think i can count out the reflashing. I just hope i dont tear into my truck only to find out its more complicated then the facility im using can handle.
