Leak at Oh S___t handles
Old Jun 17, 2011 | 06:15 PM
Dragonrep's Avatar
Dragonrep
Default Leak at Oh S___t handles
We just had a frog strangling pour down and I have water coming from both handles above the dash. I've read that it could be caused by sunroof drain lines clogging, but I can't find where the drain lines are. I know they are supposed to be in the corners, do I have to remove something to find them? or are they in the back corner somewhere?
Old Jun 17, 2011 | 10:17 PM
lxman1's Avatar
lxman1
Site Moderator
I think they are in the from corners and run down the pillars to the cowl area.
Old Jun 17, 2011 | 10:23 PM
HouseApe's Avatar
HouseApe
Open the front doors and look down from the top hing on the jamb. The pice of rubber sicking out is the end of the tube. Open it up and see if anything comes out.
The other end youll need to open the S/R and look in each corrner and you will see the drain hole. You can use some air to blow the tubes out.
Old Jun 20, 2011 | 07:23 PM
Dragonrep's Avatar
Dragonrep
Thanks, I'll look for the tubes at the doors. I looked in the corners of the sunroof, but nothing stood out as a drain.
Old Jun 24, 2011 | 08:08 AM
gman74's Avatar
gman74
open sunroof there is 2 one in each corner take some weed wacker trim push thru holes
Old Jun 24, 2011 | 08:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There is a TSB on this also
