Pressing Brake Kills throttle
Old Jun 17, 2011 | 11:22 PM
jhart's Avatar
jhart
Default Pressing Brake Kills throttle
Please help. I transplanted a 5.7L hemi from a 2004 dodge ram into a Jeep CJ7 and now after 3000 miles whenever I press on the brake the throttle is non responsive.... If I let off the brake, the throttle comes back. If I reach under the dash and press on the brake switch the throttle works again. How is this possible... I have replaced the brake module twice. Also, whenever this happens the tranny wont shift out of 3rd gear. I get a P0700 code which I understand to be just a general tranny problem. Any help would be apreciated.
J
Old Jun 18, 2011 | 09:50 PM
lxman1's Avatar
lxman1
Site Moderator
Sure you don't have a bad ground somewhere and maybe getting feedback somehow?
Old Jun 22, 2011 | 01:52 AM
ram15hun's Avatar
ram15hun
its a default if it was a 1500 a little light with a lightning bolt would come on and a apps/ brake correlation code sets I am a chrysler tech get guys come in after a whiskey night tryn to be a showoff doin burnouts with the light on and a code set dont hit gas and brake at same time problem fixed
Old Jun 24, 2011 | 09:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When you swapped this HEMI over did you use and matching PCM and harness with it also?
