P0730 Engine Code
Old Jun 20, 2011 | 05:19 PM
Auburn5.7's Avatar
Auburn5.7
Default P0730 Engine Code
2005 Dodge Ram 1500 5.7
Incorrect Gear Ration 1 is the output from the code reader.
What would you recommend to troubleshoot this?
Symptoms of the problem include:
From a fresh start, if I put the truck in drive it will either stall out or die before I get very far. It seems once the truck is warmed up I don't have this problem. Usually only happens from a cold start. Only happens in first gear. Shifts fine though.
Old Jun 20, 2011 | 11:07 PM
Owensue's Avatar
Owensue
You could try cleaning the input and output speed sensors on the tranny.
How is the fluid? Has it been changed?
Old Jun 20, 2011 | 11:10 PM
Owensue's Avatar
Owensue
Or you could always replace them, about 25$ each.
