Shift solenoid...
Old Jul 2, 2011 | 10:54 AM
NJMandCEM's Avatar
NJMandCEM
Default Shift solenoid...
Any one know hard it is to drop the trasmission pan and vavle body?? i'm sure my shift solenoid crapped out and got a quote of several hundred dollars... just lookin for some help... thanks..
Old Jul 2, 2011 | 06:11 PM
lxman1's Avatar
lxman1
Site Moderator
Not a major deal just be careful to watch how it all comes apart so you can put it back together correctly. The filter o-rings are a common problem if not reinstalled correctly.
Old Jul 2, 2011 | 10:09 PM
devanwon's Avatar
devanwon
ill let you know, im doing mine tomorrow..... also anyone know how much a drain and refill of trans fluid it will take and best brand/type to use??
Old Jul 2, 2011 | 10:36 PM
lxman1's Avatar
lxman1
Site Moderator
I would just use the ATF+4 like came in it. it is a synthetic fluid and available at Walmart.
Valvoline, or any other name brand will work fine.
Old Jul 2, 2011 | 11:11 PM
NJMandCEM's Avatar
NJMandCEM
Let me know how hard you think it is.. i can do the work.. just wonderin if it's worth me doin it or someone else..
Old Jul 2, 2011 | 11:16 PM
Dodge Tech's Avatar
Dodge Tech
whats trans do U have? and what are the codes?
Old Jul 3, 2011 | 01:42 AM
NJMandCEM's Avatar
NJMandCEM
Crap... i can't remember the trans... i think the 4-5rfe? it's a 07 1500 TRX4 with the hemi and auto tranny... i'm gettin P0750... i'm takin it in to a shop on tuesday for the final verdict but this is what i'm planning on doing/having done...
Old Jul 3, 2011 | 08:25 AM
dirtydog's Avatar
dirtydog
Moderate User
You have a 545rfe trans. ATF+4 at Walmart Can be used but is NOT reccomended by Chrysler. The reason is because Mopar ATF+4 has Lubrizol in it. The other ATF+4 do not which change the friction and surface temperatures of the clutch discs and plates. I read this entire detailed article strictly about Mopar ATF+4 trans fluid.
If I replace fluid in my truck, it will be with either Mopar ATF+4 or a complete flush using a Full Sythetic as Mopar ATF+4 is actually Not Sythetic, but a semi-Synthetic if you will. The Lubrizol is used to cheat around using Synthetic all while saving Chrysler money.
Pan hold 7.5qts I think? Entire system is upwards of 17-18qts for a flush.
2wd and 4wd filters are different. If you unhook the retun line going into the transmission, put it into a bucket and just start your truck until the fluid gets sputery. That empties out your trans pan and makes dropping the pan a zero mess job!!!
Old Jul 3, 2011 | 02:05 PM
lxman1's Avatar
lxman1
Site Moderator
Walmart sells Mopar ATF+4, that's what I was referring too. Sorry for the confusion.
Old Jul 3, 2011 | 02:38 PM
dirtydog's Avatar
dirtydog
Moderate User
If it says ATF+4 on the bottle your OK. If it says Compatible with ATF+4 then NO, NOT OK. The licensed ATF+4 requires Lubrizol formulations or the bottle can't be stamped. Compatible is Not ATF+4. I just want to make sure nobody uses the wrong stuff. Tranny's aren't cheap.
HERE is a list. Pretty much covers most brands anways.
