Cost of removing a lift
Old Jul 4, 2011 | 03:19 PM
timg32's Avatar
timg32
Default Cost of removing a lift
How much would it cost to remove 5"s of lift from a dodge ram 1500?
Old Jul 5, 2011 | 01:15 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. First, before anything else, please read this.
Are you removing 5" of a lift kit, or removing 5" from a stock height Ram? What are the specs of the Ram? (4x4, 4x2, engine size, tire size, trim level, options, etc. etc.)
What model year?
Old Jul 5, 2011 | 12:21 PM
timg32's Avatar
timg32
lift kit....2005 dodge ram laramie 4x4. It as 35 in tires but I would like to downsize those too
Old Jul 5, 2011 | 04:06 PM
jasonw's Avatar
jasonw
Site Moderator
I will move this to the 3rd gen section, get you some help.
Old Jul 5, 2011 | 06:45 PM
scwpd's Avatar
scwpd
It kinda depends on the lift is it spindles for front and leafs for back or springs and level kit up front and blocks in back
Old Jul 6, 2011 | 12:00 PM
Matt99's Avatar
Matt99
explain your lift kit. What brand, what kind of lift, what kind of tires/rims are you buying and trying to fit. is it a boxed subframe lift? torsion tweak with body lift?
whatever lift it is, you could probably sell it for as much or more than it will cost to remove IF you have the stock parts.
Old Jul 6, 2011 | 03:24 PM
HammerZ71's Avatar
HammerZ71
Won't cost nothing if you remove it yourself. Ain't hard.
Key here is IF you have the stock components to go back on it...
