Will 33x-12.5 x20 rub
Old Jul 5, 2011 | 10:56 PM
RAM_IT_07's Avatar
RAM_IT_07
Default Will 33x-12.5 x20 rub
Ok guys i ha e read the tire fitment guide ,but i didnt see anything about 33x12.5x20 on a stock rim ... Will they rub ??? All stock no lift
Old Jul 6, 2011 | 07:05 AM
HammerZ71's Avatar
HammerZ71
Height is fine, width will probably be an issue on the stock rim. The backspacing of the stock rim is just terrible for a wide tire.
Old Jul 6, 2011 | 09:06 AM
nateroach's Avatar
nateroach
If you have an 07 (as I am inferring from your name) you will not fit without spacers. read Dirty Dog's tire fitment thread.
https://dodgeforum.com/forum/3rd-gen...dodge-ram.html
Originally Posted by dirtydog
Since the Tire posts are absolutely overwhelming and it seems nobody wants to use the FAQ section or Search functions, so I decided to make this thread about what WILL fit. To add what Hammer posted HERE
Dodge Ram 1500 2wd 2002-2008
stock truck/wheels...you can fit 33's no problems(go bigger and you need a 2"lift/level)
2"+lift w/stock wheels....fit up to 35" no problems
5.5"-4.5" backspacing is ideal for anything larger/wider than 33"/12"
4"+ lift fitment will vary, use the above link and Search to find your size.
Dodge Ram 1500 4wd 2006-2008
Stock everything...fitment is limited to width on these trucks more than height with stock wheels. 34" x 11.5" is the absolute widest possible! Any wider and tire contacts upper a-arm balljoint.
stock wheels w/1/4" spacers will fit 35" x 12". They WILL NOT fit 35" x12.5" as that extra .5" makes the difference. Your tire will be about 1/4" away from the ballljoint with a 34" x 12" tire WITH 1/4" spacers. Fitment is up to you. Don't hate if they don't fit.
5.5"-4.5" backspaced wheels will allow 35"x12.5" tires silght rub at full lock.
aftermarket wheels as above PLUS 2"+ lift/level will fit 36's no problems(standard width of 12.5)
Dodge Ram 2500 2002-2008
Fit up to 34's on stock everything.
35's will scrub at full lock on stock everything
2"+lift/level will clear 35's no rubbing at all.
I deleted parts of his post to be concise, but if you have other questions i suggest reading the post in it's entirety.
nateroach
Old Jul 6, 2011 | 11:00 PM
RAM_IT_07's Avatar
RAM_IT_07
Well they fit!!!!!!! I tried them with no spacers and there was a lil rub o. The upper control arm , so i wend and bought some 5/16 th spacers and slaped them on and man this thing looks mean with nittos on it ill post some pic tom .... Thanks for the responce
Old Jul 8, 2011 | 02:26 AM
RAM_IT_07's Avatar
RAM_IT_07
File Type: jpg
Last edited by dirtydog; Jul 8, 2011 at 11:52 AM. Reason: fixed pics so browser wasn't super wide.
Old Jul 8, 2011 | 02:27 AM
RAM_IT_07's Avatar
RAM_IT_07
Old Jul 8, 2011 | 12:44 PM
HammerZ71's Avatar
HammerZ71
Not much sidewall there for serious off-roadin', but they look real nice...
Old Jul 8, 2011 | 04:46 PM
RAM_IT_07's Avatar
RAM_IT_07
It has more than you think, im gonna level the front and she will look baddddd
Old Jul 8, 2011 | 06:01 PM
ramin44s's Avatar
ramin44s
Looks good man
Old Jul 8, 2011 | 08:08 PM
RAM_IT_07's Avatar
RAM_IT_07
Thanks they had a guy on cl that had them for sale he wanted 500 for them but took 400, these thing have 18/32s on them
