2006 2WD Dodge Ram Hemi Pinion Seal Leak
My pinion seal is leaking. I've got fluid on the diff case itself and on the side of my fuel tank from it being slung around...Apparently this is a very common problem from what I am reading. I have swapped seals before, but I'm needing a shop to do this one...Do you guys think I should take it to the dealership and get it done or take it to a transmission shop? I know which one will be cheaper, but I dont want them to screw something up either...Anybody else on here had a regular shop replace on?
thanks for the input.
Prob around $300. $2 for Labor and $1 for parts/fluid.
You can get a double lipped seal fom NAPA for $10 and [2.25qts fr open diff] 75w-140 Synthetic($60) or [2qts and a bottle of modifier($45) for LSD]
