2003 hemi help<..
just got it a week ago..couple things need to fix..
1. rear end sqeaks sometimes when going over bump and added weight to the bed
2.tiny rust spot on the driver side rear end next to the bumper..whats the best fix for this and how to do it?
3.does this truck hace a timing belt or chain?..80k on the truck
4.when does the tranny fluid need to be changed?..truck shift fine right now
5.can i run is on regular gas?
6.will a 3 ton jack handle jacking the truck up?
7.whats does the truck weigh? its a regular cab 6 1/4 bed hemi 5.7
See answers in bold below
1. rear end sqeaks sometimes when going over bump and added weight to the bed - sounds like spring or bushing
2.tiny rust spot on the driver side rear end next to the bumper..whats the best fix for this and how to do it? - on the body or frame?
3.does this truck hace a timing belt or chain?..80k on the truck - chain
4.when does the tranny fluid need to be changed?..truck shift fine right now - regular scheduled changes are in the owner's manual
5.can i run is on regular gas? - technically yes, but the hemi is recommended for 89, however they're your pistons, so its your choice
6.will a 3 ton jack handle jacking the truck up? - yes
7.whats does the truck weigh? its a regular cab 6 1/4 bed hemi 5.7 - less than 5300lbs, which is what a short bed quad cab weighs
1. rear end sqeaks sometimes when going over bump and added weight to the bed - sounds like spring or bushing--how do i see which one it is?
2.tiny rust spot on the driver side rear end next to the bumper..whats the best fix for this and how to do it? - on the body or frame?--body
3.does this truck hace a timing belt or chain?..80k on the truck - chain-sweet so it wont break right?
5.can i run is on regular gas? - technically yes, but the hemi is recommended for 89, however they're your pistons, so its your choice-ok cool ive been running plus
1. You need to get under the truck and have someone bounce on the back bumper and see where the sound originates.
2. I don't do body work. sorry
3. Chain should last a long time.
4. Yep, check the manual. 60K I think
5. 89 is highly recommended
6. Enough said
7. My QCSB weighs 5260lbs.
