leveling 2wd ram 2007 help please
Old Jul 29, 2011 | 08:31 AM
ramcrazy2011's Avatar
ramcrazy2011
Default leveling 2wd ram 2007 help please
i have a 2007 dodge ram 1500 2wd and i have put a 1.5" daystar leveling kit on the front and honestly cany even tell its there i have been looking on the forums and can see alot of ya'll have yours leveled (the front as high as the back) and i was wondering what kit ya'll have to do it any help would be awsome i see some say procomp but thats all it says so if you know anyhting i am all ears thanks guys
Old Jul 29, 2011 | 09:01 AM
Brandon Anderson's Avatar
Brandon Anderson
The absolute easiest way to level front to back, is the 3" spindle from airbagit/chassistech. If you already have the 1.5" spacer in the front, you would also need a 2" block in the rear to keep yourself near level.
Old Jul 30, 2011 | 01:06 AM
DANIEL EARLS's Avatar
DANIEL EARLS
Yeah get the spindles level the truck to within a half inch. The look is the way those trucks should have off the assembly lineleveling 2wd ram 2007 help please-1302472399580.jpg
Old Jul 31, 2011 | 12:32 AM
Matt99's Avatar
Matt99
Like previously stated, the spindles are what really help the 06-08 rams since spacers dont really work with the trucks. The stock isolator is like .75" so you aren't gaining too much with a 1.5" spacer, but 2.5"/2" spacers make the UCA hit the spring bucket. Im dealing with that and after like 2 years of rough ride, will probably go back to the 1.5"s.
I did a write up in the DIY on installing them
Old Jul 31, 2011 | 07:38 PM
hdoggie24's Avatar
hdoggie24
i saw on another thread that you can put the daystar spacer on top of the stock isolater so you get more lift than if you just replaced it. is that how most people do it or is it better to remove the stock one first?
Old Aug 1, 2011 | 03:55 PM
ramcrazy2011
Ight thanks for all the help guys ill let you know how it turns out
Old Aug 2, 2011 | 02:13 AM
Matt99's Avatar
Matt99
sounds like a plan. Make sure to post pics/reviews
