tail lights.....ASAP
Old Jul 30, 2011 | 04:42 PM
Unperfected's Avatar
Unperfected
Default tail lights.....ASAP
can i put 07 tail lights on my 06 if i have the bulbs assembly thats on the back of them or is it a different connector? need help asap as im going to trade a guy in an hour....
Thanks
Old Jul 30, 2011 | 07:42 PM
Owensue's Avatar
Owensue
Download the parts lists for the 06 & 07 from the FAQ section and look at the part #'s.
Old Jul 31, 2011 | 07:53 PM
lxman1's Avatar
lxman1
Site Moderator
No, the wire harnesses are different. The brake and turn signals are wired separate on the 02-06 and together on the 07-08.
Old Aug 1, 2011 | 05:42 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
However, with the change of the wiring, they will fit and work
Old Aug 10, 2011 | 09:25 PM
Unperfected
sorry guys its been a while, did get them working lxman1 is right that the wiring is completely diff.... 02-06 has a seperate wire for each turn and brake, where the 07-09 have a wire for both blinker and brakes. All i had to do was get a vehicle light to trailer light digital converter which take the 2 wire system and converts it to a single wire. They work great and look great, i have not had a light out issue either
