Intake Issue?
Old Aug 1, 2011 | 02:18 AM
Bluelu00's Avatar
Bluelu00
Default Intake Issue?
I just bought a 2003 Ram 1500 with a Hemi. The truck has a K&N cold air intake installed. When under hard accelleration the truck really growls, and it seems to have no more gain in accelleration from about 1/2 throttle to full. It has great accelleration when driven normal, but it seems like something is not quite right when I step on it. I wouldn't say it bogs out, but the only effect from stepping on it is more growling, but no noticeable difference in accelleration. The MAF sensor had fallen out and was just hanging by the wires when I got it, so I used MAF cleaner on it and re-installed it. I have not had it checked yet, but the check engine light is on and the previous owner said it has been like that since the intake was installed. My question is: Is this just how the truck performs, or is there an issue?
Old Aug 1, 2011 | 04:24 AM
abarmby's Avatar
abarmby
Do the "key dance" and pull the code from the oddometer display.
It works for 03's as I do it on mine often.
The key dance is, turn the ignition to the "on" position and not to turn over the engine 3 times. This should be a quick rapid action and should not take more than 2-3 seconds.
Ie off-on-off-on-off and then on the third "on" where the ignition lights are glowing, leave it and look at where your miles/trip counter is.
It will start to display a character for example P, then a 4 digit number.
Right all these down as you may have several stored in the PCM.
When the display says done....switch off.
Post up your codes and we'll take it from there. The codes can be letters other than P in my example, so write them all carefully down.
There maybe several issues that will generate codes, which will indicate if your trucks poorly.
Hope this helps and post up.
Al.
Old Aug 1, 2011 | 05:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. It is normal for more growl from a CAI. However, get that MAF fixed ASAP and fix your intake leak.
Old Aug 1, 2011 | 06:32 PM
Bluelu00's Avatar
Bluelu00
Thank you. I am already impressed with this site. I asked the previous owner if he noticed a difference after installing the CAI and he said not much other than the growl, so I am aware of that.
Old Aug 1, 2011 | 06:36 PM
Bluelu00's Avatar
Bluelu00
Okay Al, I did the "Key Dance" and here are the codes it gave me:
P0442
P0513
P0138
Old Aug 1, 2011 | 11:59 PM
Owensue's Avatar
Owensue
Try the following remedy's for your CELs. I get the p0138 also after my cai install at low speeds, it goes away after running it out. Your PCM could probably use a reset and learn your acceleration and driving methods, compared to the previous owner.
P0442= evaporator leak, check hoses by evap canister for cracks or rot.
P0513= incorrect skim key, reset the PCM ( disconnect bat neg)
P0138= o2sensor issue, right bank 2nd sensor. Replace o2 sensor
Hope this helps.
Old Aug 9, 2011 | 11:51 PM
Bluelu00's Avatar
Bluelu00
I checked the hoses by the evap. canister and found large cracks on one of the hoses. I cut the end of the hose off and re-attached it. I think the security code was because I had a key made that did not have the chip in it. I haven't done anything about the sensor, but the CEL has not been on since I checked the codes.
