Problems with control solenoid
Old Aug 7, 2011 | 03:16 PM
bulldogradio1's Avatar
bulldogradio1
Unhappy Problems with control solenoid
Hello everyone,
Does anyone knows where the transmission control solenoid is located on a Dodge Ram 1500 Hemmi? Please help me out, I spend the last 3 hours trying to locate this part but no luck.
Old Aug 7, 2011 | 03:31 PM
vpnavy's Avatar
vpnavy
Welcome aboard bulldogradio1! I'm sure a Technician will jump in shortly. In the meantime, you might want to browse Sub-Forums: Dodge Ram for stuff related to your ride.
Old Aug 7, 2011 | 03:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Until your post gets moved to the truck ram section, Yes I do. Is inside the transmission and is bolted to the top of the valve body.
Old Aug 7, 2011 | 05:02 PM
bulldogradio1
Default Wowww
Is this something I can do my self or will I need to take the truck to a shop so they can take the transmission apart?
Old Aug 7, 2011 | 05:03 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. What year is your Ram?
FF
Old Aug 7, 2011 | 05:04 PM
bulldogradio1
Default Tank you mastertech
Is this something I can do my self?
Old Aug 7, 2011 | 05:06 PM
bulldogradio1
Default It's a Ram 1500 hemmi 2004
Old Aug 7, 2011 | 05:28 PM
Owensue's Avatar
Owensue
If you have a 545rfe automatic transmission you have a solenoid pack as mentioned mounted to the top of the valve body. Yes you can do it yourself under the truck, drop the pan, filters and valve body remove and replace the solenoid pack.
Look at the drivers side of your transmission where the large electrical connector is, that is for the solenoid pack. Old ones are black, newer white ones can be used to replace this with an adapter plate.
Hope that helps.
Old Aug 7, 2011 | 07:32 PM
master tech
Just like Owensue had said. So here some information. And yes it you can do it yourself.
REMOVAL
NOTE: The valve body can be removed for service without having to remove the transmission assembly. The valve body can be disassembled for cleaning and inspection of the individual components.
Shift transmission into PARK.
Raise vehicle.
Disconnect wires at the solenoid and pressure switch assembly connector.
Position drain pan under transmission oil pan.
Remove transmission oil pan.
Remove the primary oil filter (1) from valve body. (Remove Primary Oil Filter)
Remove bolts (1) attaching valve body to transmission case.(Valve Body Bolts)
Lower the valve body and work the electrical connector out of transmission case.
Separate the valve body from the transmission.
Old Nov 21, 2011 | 08:38 AM
tracy henry's Avatar
tracy henry
thanks so much. i sure couldn't find it nowhere on exterior of trans.
