headlights stayed on when i shut truck off-curious this just started
Old Aug 7, 2011 | 09:13 PM
hondarancher4435's Avatar
hondarancher4435
Default headlights stayed on when i shut truck off-curious this just started
i have and 06 1500 mega cab bought it a week ago. anyway usually i shut the lights off then the truck today i shut the truck off then shut the lights off hopped out and realized the lights were still on. opened the door up and the switch was off. then i messed with it a few times to see if it continued and yes if i shut the lights off after the ignition then the lights will stay on for about 3 minutes before going off however the fog lights shut off. is this normal?
also any way to make the lights flash when i lock/unlock the truck or make all 4 doors unlock with just one press off the remote button. i don't have an owners manual so i'm not sure if it covers this stuff or not
Old Aug 7, 2011 | 09:19 PM
Kscha41's Avatar
Kscha41
Yes it is normal for the lights to stay on if you turn them off after you turn your truck off.
Old Aug 7, 2011 | 09:21 PM
MikeHTally's Avatar
MikeHTally
Sometimes I forget to turn mine off before shutting done the warp drive. They stay on about 30 seconds, running down my battery. Aggravating.
Old Aug 7, 2011 | 09:59 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, if you turn off the truck, then the lights, the lights stay on 30-45 seconds.
Old Aug 7, 2011 | 10:17 PM
hondarancher4435
cool so could you just leave the light switch on all the time and lights would stay on about a minute after you shut down and then just come back on when you restart?
sorry coming from a 96 12v cummins so all these new fancy features will take time to learn haha
Old Aug 7, 2011 | 10:23 PM
dnlo613's Avatar
dnlo613
my 06' just the marker lights flash on lock/unlock,also it's standard on every car that i've worked on that the key fob only unlocks the driver's door w/the first push then the other's after 2x.
Old Aug 7, 2011 | 10:29 PM
scwpd's Avatar
scwpd
you could leave the lights on but i wouldn't a guy i work with just got a charger pursuit and he kept leaving his lights on when he turned it off to goto work and eventually he came to work and the battery was dead as a door nail
froy's Avatar
froy
From page 22 of the owners manual
The system can be programmed to unlock all the doors or
drivers door only upon the first UNLOCK button press
by using the following procedure:
1. Perform this operation while standing outside the
vehicle.
2. Press and hold the LOCK button on your key fob.
3. Continue to hold the LOCK button at least 4 seconds,
but no longer than 10 seconds, then press and hold the
UNLOCK button while still holding the LOCK button.
4. Release both buttons at the same time.
5. This will allow you to unlock all doors on the first
press of the UNLOCK button.
Old Aug 7, 2011 | 10:31 PM
dnlo613's Avatar
dnlo613
you must have posted when I was replying.no you cannot leave your lights on all the time,they will only stay on temp if you shut off your ign.,then your lights.they will not shut themselves off....
Old Aug 7, 2011 | 10:38 PM
dnlo613's Avatar
dnlo613
Froy-thanx I didn't know that we could do that on our trucks,guess i should've read more...
