Transfer case help.
Old Aug 7, 2011 | 10:19 PM
koondawg's Avatar
koondawg
Default Transfer case help.
So my truck was leaking at the output shaft seal. I changed it and it is leaking worse. Its gotta be the extension housing or the driveshaft yoke. I have a new extension housing coming but I am not sure about the gasket between the t-case and the extension. I downloaded weeds part numbers but it doesnt show anything. Anyone? I guess ill check the driveshaft yoke also. It had a nick in it, but not bad. new seal seemed to go in fine but i nicked the were it seats a little with the seal puller.
Old Aug 7, 2011 | 10:20 PM
koondawg's Avatar
koondawg
o yea Tcase is a 241d.
Old Aug 7, 2011 | 11:21 PM
draco8494's Avatar
draco8494
if in doubt use some ultra grey high tourq gasket maker...love the stuff..hard as crap to get it off tho
Old Aug 8, 2011 | 08:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Or some metal filler like JB Weld.
Old Aug 8, 2011 | 08:41 AM
koondawg's Avatar
koondawg
weed are you talkin on the yoke? Draco thats what im thinkin if i cant find a gasket. thanks guys.
Old Aug 8, 2011 | 09:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well I guess it would depend on how bad the gouge or nick is. Maybe the seal is bad (new one)
Old Aug 8, 2011 | 11:18 AM
koondawg's Avatar
koondawg
ya i was gonna pull the driveshaft and make sure the little spring in the seal didnt come out. I dont think it did. driveshaft slide in pretty easy and straight.
Old Aug 8, 2011 | 06:33 PM
dirtydog's Avatar
dirtydog
Moderate User
You probably seated the seal crooked? It doesn't take much. As for the nick, get yourself a double lipped seal and that will eliminate your problem. As long as the nick is inward(meaning use emery paper to smooth the outer edge, you shouldn't have any problems. I would advise against using jb weld, but it's your truck. I only say this because you would actually have to roughen the inside of the nick for the JB to stick to and if it ever broke loose and went inside your trans, it could cause problems, maybe I'm just being a sally?...lol
Old Aug 12, 2011 | 08:09 AM
koondawg's Avatar
koondawg
Well its finally fixed. I tried two different national output shaft seals (part #4333N). Still leaked after each. So I bought a new extension housing with a OEM seal in it.
While I had both housings and seals side by side and the driveshaft out, I slide each over the yoke and the aftermarket seal didnt fit nearly as snug as the oem.
So if your replacing your seal with this Part may want to check before you install. I did the hole housing and seal in 30 min compared to 2 hrs fighting with just the aftermarket seal. Anyway no more leak.
