Mods for 5.7 Hemi
Old Jul 21, 2005 | 06:00 PM
  #21
CanynroChris's Avatar
CanynroChris
Default RE: Mods for 5.7 Hemi
So you CAN put on a turbo on a Hemi in just a weekend. Considering it. Thanks for the thread on this.
Old Jul 21, 2005 | 07:07 PM
  #22
guitarded's Avatar
guitarded
took me around 10 hours altogether by myself in some pretty hot weather. you may experience some stalling and eratic idle, or engine throttling. But that's the pcm adapting to the system.
Also, if you order the sts, be sure to check your sea level elevation so they can provide you with the correct injector for your altitude. Keni Hemi's really good about any questions you may have.
Also, go for the upgrade kit with boost control.....if your gonna invest in the system, might as well go all the way!
Old Jul 21, 2005 | 07:10 PM
  #23
guitarded's Avatar
guitarded
almost forgot...........if you're gonna get the upgrade boost control, grab the air to water intercooler as well. You're gonna need it to run 8-9 lbs boost.
Old Jul 21, 2005 | 07:35 PM
  #24
guitarded's Avatar
guitarded
just out of curiosity, where'd you get your gears hemifever?
is you're front diff 205mm?
Old Jul 22, 2005 | 10:04 AM
  #25
hemifever's Avatar
hemifever
SPONSOR
guitarded, Yea I've got the 8" front on my '03. I got the gears from someone out of Texas. Air Ram on DTO (he's probably on here too) hooked me up with the dude. Randy's Ring and Pinion was out of stock when I bought last year.
