New to Forums! Need help with truck!
Old Aug 19, 2011 | 04:18 PM
Go_Green's Avatar
Go_Green
Originally Posted by Owensue
I searched up this light bar, it needs a good ground, three positive triggers left, right, and brake.
try using a battery to identify each leads purpose and rewire accordingly. Tapping in to the wires behind the 7 way should be easy. If your taking everything from 1 side you don't get left and right.
Originally Posted by TurboPower1254
Might be wrong but could it also be the U-Joint? Had a problem with mine on an 04 not too long ago. You will be able to hear it poping when turning or hitting the brakes. Just a thought, I like to check the less expensive parts first.
It's 2WD.
Old Aug 20, 2011 | 07:59 AM
SLT07ThunderRoad's Avatar
SLT07ThunderRoad
My driver side / front wheel bearing was replaced on my 07 this past Spring. In my situation, I could hear and feel a very obvious grinding in the front end when driving into turns, like when you use an expressway exit ramp. When driving straight, it would quiet down and seem ok.
