Rear locking up on turns?
Old Aug 15, 2011 | 07:32 AM
IndyRamMan's Avatar
IndyRamMan
Default Rear locking up on turns?
Hey guys,
Just bought my truck a week ago off a dealer. I assume this may be a common occurrance since all the trucks I looked at at dealers did this: when rounding a corner, 90* or sharper, the rear axle likes to lock and unlock through the turn chirping the tires with or without any gas being applied. Now I assume this may just be because the trucks have been sitting for a couple months and the rear oil has dripped out of the clutches and they're not disengaging on the turns properly until the oil gets built back into them after some driving.
All I know is, my rear did it on my truck when I bought it a week ago, but now it drives perfectly normal after driving some distance.
Anyone have any insight into this being signs of a problem or is it just what I think it is?
Old Aug 15, 2011 | 07:42 AM
SEMPERFI8387's Avatar
SEMPERFI8387
If it's a posi, that's what they do .....
Old Aug 15, 2011 | 07:54 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
No, a posi (AKA LSD) should not chirp around corners. You need to either pull the rear diff cover and check everything or at least check the oil level. A LSD needs friction modifier fluid (3oz per qt of oil). If the oil is low or no friction modifier fluid and rear end will grab around corners.
Old Aug 15, 2011 | 02:00 PM
SEMPERFI8387
Maybe I shod have said " that's what some do" I've had tight and loose LSD's over the years, tolerances can be different, and act different. My Ram is nasty in rain, but my goat is fine with an LSD
Old Aug 18, 2011 | 09:15 PM
IndyRamMan's Avatar
IndyRamMan
I figgured as much. This is the standard 9.25 that im used to on my old second gen right?
Old Aug 19, 2011 | 09:03 AM
nateroach's Avatar
nateroach
yes still the corporate 9.25" rear end.
Capacity :
Rear: 2.21 qt 75W-140 with 4oz friction modifier (many synthetics have the friction modifier in them already, just check the bottle)
Front: 1.69 qt 75W-90
nateroach
Old Aug 19, 2011 | 11:58 AM
John  M's Avatar
John M
Mine does grab a little during a right turn but it has for the last 30k miles or so. I assumed it always did it, or maybe started when I switched to these tires at that time. I admit I haven't checked the diff and it is supposedly a ticking time bomb...
Old Aug 19, 2011 | 12:33 PM
HammerZ71's Avatar
HammerZ71
Yep, I'd do a fluid change and add a bottle of friction modifier to it. I've never had an issue with my truck (which has an aftermarket Auburn LSD) but it's been changed at 15k intervals with a fresh bottle of modifier.
My Grand Cherokee has automatic lockers in both the front and rear diffs, I use synthetic fluid in it with friction modifier in it, but it wants an additional half bottle per or it'll ratchet and grab a little around turns...
Old Aug 19, 2011 | 02:05 PM
Go_Green's Avatar
Go_Green
Both of these. If you do a little research, you'll likely find out that the truck was serviced by the dealer. The tech that did the service "forgot" to add the friction modifier. Drain the oil, refill it, add the modifier, and you'll be fine.
This is exactly what happened with mine.
