2002 Ram 1500 Rear seal replacement
Old Aug 21, 2011 | 08:07 PM
Shudbe's Avatar
Shudbe
Question 2002 Ram 1500 Rear seal replacement
Hey all, I'm changing out the main rear seal in my 4.7L V8 Ram. In the Haynes manual it says to lift the engine with hoist to remove oil pan. Is there a "safe" way of lifting the engine with a floor jack?
Thanks,
Shudbe
Old Aug 22, 2011 | 12:34 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
First, before anything else, please read this:
https://dodgeforum.com/forum/dodge-ra...s-section.html
I will move you to the 3rd Gen Ram section.
Old Aug 22, 2011 | 07:45 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. I would look in the manual and see how it says to lift the engine. I would think you have to wrap a chain around it and use a cherry picker. You may also want to click on the link below in my signature and download the service manual for your truck to also help
Old Aug 22, 2011 | 05:08 PM
notfondofdodge's Avatar
notfondofdodge
just had my oil pan off my 03 and didn't have to lift the engine. I did have to beat the oil pan off the gasket/windage tray with a pry bar between the gasket and pan.
Old Aug 24, 2011 | 09:02 PM
Shudbe's Avatar
Shudbe
Default Need some help diagnosing
I’m seeing a lot of what I think is “oil” around the trans pan. Maybe the rear seal isn’t leaking.?. I drained the engine oil yesterday and now I’m seeing even more drips on the ground right under trans pan. Maybe I’m getting this confused with trans fluid.?. Sure looks like oil though!
Attached Thumbnails 2002 Ram 1500 Rear seal replacement-dscn1754.jpg   2002 Ram 1500 Rear seal replacement-dscn1756.jpg
Old Aug 24, 2011 | 09:21 PM
dirtydog's Avatar
dirtydog
Moderate User
That leak isn't all that bad. First I would spray some degreaser and rinse with a pressure sprayer. Then drive for a day and see where it's leaking as it could be up higher.
To lift your engine, you could use a piece of wood and jack up the crankpulley. That will safely lift the engine granted you have the motor mounts loose.
Old Aug 28, 2011 | 02:54 PM
HemiLonestar's Avatar
HemiLonestar
and download a real manual:
http://rapidshare.com/files/293925178/2002_Ram_1500_Service_Manual.pdf
Weedahoe has parts manuals as well
Old Sep 2, 2011 | 10:33 AM
Shudbe's Avatar
Shudbe
OK, I'm diving further into this oil leak which I thought was a rear main leak. I removed the crossmember beneath the oil pan then removed the brace between the oil pan and trans. I now have a clear view of the flex plate. I thought I would have seen oil in this area as an indication of a rear main leak. Any thoughts?
I'm now proceeding with removing the oil pan...easier said than done. Smacking it with a rubber mallet or deadblow is worthless. Now I'm taking razor blades and tapping/wedging them in between the oil pan and gasket. Very tedious!
