Looking for a diagram for pcm pins or special tool #8815
Old Aug 23, 2011 | 05:16 PM
JayDee240's Avatar
JayDee240
Default Looking for a diagram for pcm pins or special tool #8815
I think I have excessive resistance in the K4 sensor ground circuit of my MAP sensor, but I'd rather not rip my entire wiring harness apart to find it. I think the Camshaft, Crank, TPS, and MAP sensors all share the same ground. Does anyone have a diagram of the PCM connector pins? Like something that shows which pin is for what, or even which pin is what color wire. There's a tool (special tool #8815-1) that tells you exactly what I need to know but I'd like to avoid spending $220 on a tool that I will use once in my life. The truck I'm working on is a 2006 Dodge quad cab 1500 4.7. Any help would be great, thanks!
Old Aug 23, 2011 | 05:31 PM
JayDee240's Avatar
JayDee240
Nevermind. I found it right here.>>> http://www.dodge.com/bodybuilder/200...torpinouts.pdf
Old Aug 23, 2011 | 07:15 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
or even better, take the time to click on the links in my signature and download the full service manual that will answer your original problem and more
Old Aug 23, 2011 | 10:28 PM
JayDee240's Avatar
JayDee240
I've already downloaded your 2006 Ram Service Manual (many thanks for listing all these manuals by the way! :-D) but after spending a few hours reading through it, I still found no cure for my problem. It is just not descriptive enough to help me troubleshoot this F#&@ing P.O.S. truck and it's cheaply made, shorted out wiring harness.
Old Dec 31, 2020 | 05:30 PM
bcuda's Avatar
bcuda
Link no longer works - any updates?
Old Dec 31, 2020 | 05:38 PM
bcuda's Avatar
bcuda
found it elsewhere - https://vdocuments.site/8w80connectorpinouts.html
viewable online or downloadable pdf
Old Jan 1, 2021 | 11:57 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Old May 15, 2023 | 11:13 PM
Gwolf1965's Avatar
Gwolf1965
Default Pin identity
  • you can get that info from identification for $20 for a monthly price
Old May 16, 2023 | 10:34 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Old May 16, 2023 | 11:30 AM
Alex Medeiros's Avatar
Alex Medeiros
Originally Posted by Magnoom
Not often that we see two in one thread
