2003 dodge ram hemi throwing 2 codes
Old Aug 25, 2011 | 09:08 PM
mjhenson's Avatar
mjhenson
Default 2003 dodge ram hemi throwing 2 codes
I am new to this forum need you alls help. The truck has a CEL on and the codes I pulled is P0440 and P0441 which both has to do with the EVAP but truck runs fine except for the radio shuts off every now and then and I get a dash light every now and then showing lamp is out. Do I have an evap problem or is it a grounding(electrical) wire groundin out? or will the EVAP fix this if I work on this? Anyone gone thru this. 2003 dodge ram with 5.7L HEMI.
Old Aug 26, 2011 | 01:12 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
First, before anything else, please read this:
https://dodgeforum.com/forum/dodge-ra...s-section.html
I will move you to the 3rd Gen Ram section (2002-2008 Rams).
Old Aug 26, 2011 | 09:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
always welcome and please do post your issues in the 3rd gen ram section
in the meantime, crawl under the truck and check all the rubber vac evap lines going to the canister in front of the fuel tank. they are common to leak due to age and fatigue. they will collapse or get cracks in them at the nipples. also check the seal on the fuel cap
