tranny won't shift into highway speed
Old Aug 26, 2011 | 09:50 PM
stenerson's Avatar
stenerson
Default tranny won't shift into highway speed
When I get over 55mph it seems tranny not shifting into 4th gear. Been doing some googling and searching. Some say might be a solenoid.
Has anyone hear had this problem and fixed it?
Any suggestions appreciated.
Old Aug 27, 2011 | 09:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
got a check engine light on? please post the codes. im sure you checked the fluid level and have been changing the trans fluid and filters regularly right?
Old Aug 27, 2011 | 03:50 PM
stenerson's Avatar
stenerson
Fluid looks fine. No CEL codes.
Old Aug 27, 2011 | 04:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
does the cel light work? i cant see i not shifting gears and not tripping something in the pcm or tcm
Old Aug 28, 2011 | 02:56 AM
stenerson's Avatar
stenerson
I used a code reader and no codes.
Old Aug 28, 2011 | 09:42 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
then its time to take it to the shop. codes point you in a direction on where to start. if the fluids are good and filters have been changed and no shifting or codes, there is no way of knowing where to start for the average guy. at that point its time for the trains mechs and shop to take over
Old Aug 28, 2011 | 01:38 PM
stenerson's Avatar
stenerson
yep. I'm over my head here.
Old Aug 28, 2011 | 02:09 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
please let us know what you find out
Old Mar 3, 2018 | 07:08 AM
stenerson's Avatar
stenerson
Just going over some of my old threads and noticed I never gave the final resolution on a couple of them. I hate when people do that, especially when I'm googling, and someone posts a similar problem but never post how they fixed it.
Anyhow this thread is 7 years old but here's what I did. I ordered a new transmission solenoid pack. They're not cheap, couldn't find them online back then any cheaper than my local dealer.
I changed it myself. You have to remove tranny oil pan, drop the valve body (I think there were 6 bolts to do that. Then there were about 13 bolts to remove the solenoid pack from the valve body.
Here's a youtube video of guy changing it on a jeep cherokee, but looks to be the same procedure.
