Beep from the front door being open wont stop even after I take out the key!
Old Aug 27, 2011 | 10:10 AM
ccolin001's Avatar
ccolin001
Default Beep from the front door being open wont stop even after I take out the key!
So Installing a new sound system in my dads 04 Ram 3500 cummings, I already had to fix the broken wires problem, in the rear door for the window. But now the dash wont stop beeping after I take the key out. I checked the front door boot already thinking it might be a loose wire. Any help would be great. Thnx Chris
Old Aug 27, 2011 | 12:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site. I'm assuming that your lights and everything else is turned off. With that in mind, the only thing left I can think of is the ignition switch is broken and thinks that the key is still in the cylinder.
Old Aug 27, 2011 | 02:14 PM
Toefur's Avatar
Toefur
If im not mistaken the chime plays through the driver side speaker and is wired through radio. If you wired in a new receiver without a harness adapter of some kind that may be your issue.
