Fastman TB install help
Old Sep 2, 2011 | 11:50 AM
pitbull24's Avatar
pitbull24
Default Fastman TB install help
Received my TB from Dan last night, and was hoping for a quick install. I couldn't pull off the connector on top. I slid the tab over, but it didn't want to pull off easily. Any tricks, or tips? More muscle? Screw driver to pry somewhere?
Thanks.
Old Sep 2, 2011 | 09:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
more finger muscle.....LOL
once you slide the locking clip out of the way you simple press down on the tab and pull it off. its either an 8 or10mm socket needed to remove the tb
Old Sep 2, 2011 | 09:57 PM
08HEMI1500's Avatar
08HEMI1500
I had the same problem when trying to take my TB off to clean it when doing my intake. I eventually gave up so if you get it let us know what it took lol, besides more finger muscle.
Old Sep 3, 2011 | 12:55 PM
pitbull24's Avatar
pitbull24
Finger & what forearm muscle I could leverage into it couldn't break her free. Nice, narrow flat head screw driver did the trick. Didn't take much to slip it between TB & connector, and as soon as it slightly moved I was able to pull off.
Old Sep 3, 2011 | 02:12 PM
popdog's Avatar
popdog
I put on a fastman a while back and did it in literally 5 minutes... don't remember running into any issues... lol
Old Sep 3, 2011 | 03:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
also, before and after performance, idle, sound, rpms feedback would also be cool
Old Sep 3, 2011 | 10:59 PM
tafet's Avatar
tafet
Hey weed, I did mine when I dropped in the 08 intake. It was before I did exhaust and I could definately hear a change in the exhaust note. Was pulling a lot more air.. well at least on the 4.7. I figure the 5.7 should react the same.
Old Sep 7, 2011 | 11:30 AM
pitbull24's Avatar
pitbull24
I threw on an Airaid MIT at the same time. Idle and r's seemed to not chage, but def sounds like it's sucking more air & throttle seems a little crisper.
Old Sep 7, 2011 | 11:42 AM
SLT8's Avatar
SLT8
Those darn dodge connector clips are a pain. Glad you got it done.
