2007 Ram Quad Cab ABS & Brake Light Issue
Old Sep 2, 2011 | 06:20 PM
jasdas7499's Avatar
jasdas7499
Default 2007 Ram Quad Cab ABS & Brake Light Issue
My ABS Light & Brake Light both come on quite a bit (for the past week). I don't notice any difference in performance while they are on. I recently had an outer tie rod end replaced. Any ideas of what can make both lights come on? Thanks for any ideas you can give!
Old Sep 2, 2011 | 09:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
welcome to the site. there is an abs sensor on the front drivers hub and possibly the pass side also. check and/or replace as needed. also download the srvc manual for your truck from my signature link below and look through it also
Old Sep 3, 2011 | 12:15 PM
jasdas7499's Avatar
jasdas7499
Thanks for the advice!! I really appreciate it. I am not a DIY kind of guy so I will have to take it in and have it looked at.
Old Sep 3, 2011 | 12:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Since the manual in the links are all pdf, you can do a simple search function for 'abs' and find what you need very quickly. Give it a shot and do some reading and see what you can find.
IMO, the abs sensor is easy to replace if that is your problem.
Old Sep 3, 2011 | 05:24 PM
jasdas7499's Avatar
jasdas7499
I noticed this morning those lights were on when I started my truck. I drove around town for about 5 minutes, my speedometer needle went crazy (up/down/not working), then the lights came back on. Do you think the ABS sensor would cause that? Thanks again.
Old Sep 3, 2011 | 05:49 PM
freestyledude's Avatar
freestyledude
On mine when it was ABS and Brake light sensors I replaced the rear ABS sensor
