Swaping OPEN diff with LSD diff on ram ?
Old Sep 6, 2011 | 02:51 PM
adventurer's Avatar
adventurer
Default Swaping OPEN diff with LSD diff on ram ?
Hi all ,my friend bought an 06 rear axle with factory LSD on it , if he wants to replace the open diff on his 04 rumble bee with that one CAN he just open the two diffs and swap the inner stuff ?? Both are 3.92
Old Sep 6, 2011 | 10:03 PM
lxman1's Avatar
lxman1
Site Moderator
Yes, they are the same. If I didn't have one, I would go aftermarket. They are much better.
Old Sep 7, 2011 | 12:25 AM
scwpd's Avatar
scwpd
Have you heard of the c clip problem that can pretty much destroy the rear end an after market one would be a better choice
Old Sep 7, 2011 | 09:40 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
clutch pack retaining clips breaking and falling into the diff can be a potential issue but most guys (myself included) usually never notice until we pull the diff cover to inspect the diff/gears and change the oil and find them at the bottom.
Old Sep 9, 2011 | 06:34 AM
adventurer's Avatar
adventurer
so in this case the diff will act as open diff that's if ur lucky and nothing happened when the clutch pack retaining clips breaks ??
Old Sep 9, 2011 | 09:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Close. The clips hold the clutch pack together during assembly on the the diff. Once all put together they are no longer needed. However, when the break, only the W shaped ends that stick out break off which is what you find at the bottom of the differential in pieces. The rest are still in the differential itself.
Old Sep 9, 2011 | 04:50 PM
Gone Fishin's Avatar
Gone Fishin
It miht be easier and possibly less expensive just to swap out the whole rearend, if they are the same. Then you wouldn't have to have the diff setup-----just pull those c-clips or retainers or whatever they actually are while its apart.
Old Sep 9, 2011 | 05:38 PM
cjdautomotive's Avatar
cjdautomotive
If it is a 1500, it is a 9 1/4 corporate. You cannot easily make it an open diff. The Trac-Loc uses clutches pushing against two of the pinion gears (spider gears). This provides the preload and adjustment on the pinion gears as well as providing a limited slip. If you remove them, you would have to shim the pinion gears back to replace the clutches that were removed.
The clips are what keep the clutches from rotating. They are absolutely necessary and are not just for assembly. If the plates rotate then the frictions would never have anything to rub against and provide a limited slip. The plates are held by the clips to the carrier and the frictions are splined to the pinion gears. That's why you hear a moaning noise from the rear when turning if a clip is broken. These are all serviceable parts and relatively cheap...done a million.
If your in Jax, I have several open carriers laying around...
