3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 02 QC with the 5.9l. While doing some maintenance, I tried to change the distributor cap and rotor, but the screws where not moving, so I gave them a bath in PBblaster and one came out, and the other was just about there and broke off. I have the manual on how to get the distributor out. My question is, it is a tight fit in there, does anyone know if the distributor will come out without having to remove anything else?
Screw broke flush, if I use a right angle drill, I might be able to get in there to drill out. Or pre-drill with a Dremel tool then use a screw extractor.
I have the same problem on my 02 Ram. I don't see any way to get a dremel let alone a drill in under the cowl. Have you made your repair yet? If so how? I'm thinking about getting a replacement Distributor from rockauto and replaceing mine since I have 120,000 miles on the truck. I'm looking for info on how to change the distributor and what size wrench is needed, also on how to get it back in time. The last distributor I changed was before cam sensors and crankshaft sensors.
Originally Posted by 2002Rammy
I am going to do this on weekend I will update then. Oh ya, its amazing what you can do with a tie wrap in a jam. LoL.
