Wheel wells
Old Jul 21, 2005 | 01:13 PM
Hillside's Avatar
Hillside
Default Wheel wells
Like an idiot I sprayed bleach white under the rear wheel wells to clean and the black paint is coming off. Has anyone painted under there and what did you use?
Old Jul 21, 2005 | 07:28 PM
osteodoc08's Avatar
osteodoc08
Default RE: Wheel wells
If you clean it up with some alcohol, you can get the rubberized undercoating and spray it on. Just be sure to keep it away from the paint.
Old Jul 22, 2005 | 02:13 AM
Avanti's Avatar
Avanti
If you get the Mopar wheel well liners that Dodge should install on all pickups from the factory you won't have to worry next time you get carried away with the chemicals.
All the best.
[IMG]local://upfiles/14944/65E320F5916645818D553B93A3E60398.jpg[/IMG]
Old Jul 22, 2005 | 05:52 PM
AbramsM1's Avatar
AbramsM1
Avanti-
Those look pretty nice. 2 Questions:
1. Are they for the front and rear wheel wells?
2. How was the price?
Thanks,
Abrams
Old Jul 22, 2005 | 05:56 PM
moparturd's Avatar
moparturd
Those are the rears and they are less than $80. Takes about 20 minutes to install too.
Old Jul 22, 2005 | 11:44 PM
Bruce's Avatar
Bruce
I put a set on a few weeks ago,$100 shipped and a very easy to fit.
Old Jul 23, 2005 | 12:25 AM
AIR RAM's Avatar
AIR RAM
Yeahh I added those a while back... LOVE THEM! They really make the truck look better also,
SPEED SAFE, AIR RAM
Old Jul 24, 2005 | 12:52 AM
Avanti's Avatar
Avanti
IMHO, all Rams should be built with the "factory" liners. They come as a "kit" with all fasteners for installation (all holes are already there) and fit perfectly.
Highly recommended.
[IMG]local://upfiles/14944/44B97436F35E48D6B533F78C87EF874E.jpg[/IMG]
Old Jul 24, 2005 | 09:36 PM
billbeam's Avatar
billbeam
Was considering getting the Wheel Well Liners. Any problem installing them with the Molded Splash Guards?
Thanks.
Old Jul 25, 2005 | 07:49 PM
cve's Avatar
cve
I put the liners on with the mud flaps and they use the same holes for the flaps. One caveat, the flaps have a plastic push plug that has to be put into the liner. Small issue, everything is solid once done.
