Trailer Brake Control Wiring
Old Sep 25, 2011 | 05:50 PM
zbiggboy's Avatar
zbiggboy
Default Trailer Brake Control Wiring
Hi all,
Okay I found the 4 Flat Pin connector under the dash on the left side. So I can plug in my brake control. On the rear of the truck where is the harness I need to set up for the 7 Pin plug? I really don't want to drop $100 bucks to buy a harness from the stealership.
'08 Ram 1500 Quad Cab Big Horn Edition.
Thanks in advance for the help.
James
Old Sep 25, 2011 | 07:34 PM
MikeHTally's Avatar
MikeHTally
The seven-pin should be next to the tag.
Old Sep 25, 2011 | 07:47 PM
lxman1's Avatar
lxman1
Site Moderator
If you don't want to by the harness, you will have to run your own wires from the cab to the back bumper.
Old Sep 25, 2011 | 10:00 PM
zbiggboy's Avatar
zbiggboy
Should i lower the spare tire to look for it? On my '05 it didn't have the plug in the cab for the brake control. I had to buy and run the harness for that truck.
Thanks for your help.
