12" Puller/Pusher E Fan Install
Old Oct 24, 2011 | 04:12 PM
xtremedurb00's Avatar
xtremedurb00
Default 12" Puller/Pusher E Fan Install
I got this 12" e fan from a 94' Ford Thunderbird SC that was used for the intercooler. When I finally figured out how to mount it, I decided to put it from of my tranny cooler and got started...
You can't see it from this angle but on the right side, I had the trim the shroud a little bit to get it to fit over the oil cooler
I ran the power, source and ground wire along the driver side fender
Both grounds for the switch and e fan along with the source wire
Source, power and ground wires ran through the firewall on the driver side
Wires ran through the firewall going to the switch
This plastic piece finally became useful
Everything from start to finish only took me about 3 hours.
Old Oct 24, 2011 | 05:51 PM
dodgeboy1979's Avatar
dodgeboy1979
Cool, nice work, is it hooked to a thermostat or manual operation only?
Old Oct 24, 2011 | 08:58 PM
xtremedurb00
Its manual, I got it hooked up to the switch alone this way I can turn it on whenever I'm towing something or just to help cool down the tranny.
Old Oct 24, 2011 | 10:40 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
so i assume you are keeping your stock clutch fan also
Old Oct 25, 2011 | 12:59 PM
xtremedurb00
Yeah I am...I'll throw it in the back of the truck like a spare tire for now just in case something was to happen to the e fan. Atleast for a little while until I see how the e fan runs.
