Parking lights stay on
Thanks. Yeah I looked on ebay and found a few used ones. I really want to avoid getting a used one so I'm not going to even bother going to the junkyard. I go to the junk yard for other things, but I would like to fix this and be done with it. I also looked on Rock Auto and did not see a listing for it. I thought I remember reading on here that people where getting it for three something, so I was wondering if they found an aftermarket or if that was from a dealer.
The price also seems to fluctuate between dealers. I think last week another thread about this, one guy was quoted $475 or so, and someone else in a different state was quoted over $600!
Sorry, I don't even know why I suggested rockauto (my mind must have wandered to something else). The fuse box is hard to come by without the dealer... But maybe try www.wholesalemopar.com
Well I was looking on RockAuto earlier and I found a parking light relay. Its not the one though that goes in the fuse box. Would something like this go bad. And does anyone know where it goes. Here is a link to it. http://www.rockauto.com/catalog/moreinfo.php?pk=945754
I noticed that Auto Zone has the same relay listed also. So its not just Rockauto. I wonder if thats what causing my lights to stay on? Also does anyone know where this relay is located?
Well I was doing some more research today before I spend $343 on something that may not fix my problem. I read that the switch, cluster, PDC, or the FCM can cause this. A lot things and a lot of people point me towards the PDC but I just want to make sure it is before I buy it. I read online earlier that if I disconnect the FCM and the lights stay on still, it is most likely the PDC. How do I know that its not my cluster causing this? Its weird because my dash lights don't stay on like the parking lights do. They do work when you use the switch. I don't know, all this stuff confuses me.
Did you take apart yours yet? Before you buy a new one make sure yours is
corroded first. Yes, you have to drill out the plastic tabs to get apart. But if its not corroded you can still put it back together and use it. . also if you get a used one its probably going to have corrosion too,,,,. I believe the new ones are ugraded to stop the problem but I’m not 100% sure..at least try and fix your before you spend the money. you may be able to get away with just cleaning it and not having to Solder the board.
You can also bypass it by hooking up a relay to trigger from your headlights and turn on the parking lights at the same time.
Just run a relay with a hot wire going to the parking lights at the bulb and run a wire from the headlights to the relay as your turn on switch.
Well I think I found the problem. I spent about an half an hour taking the thing apart. Everything looks clean except for one spot. The one spot is right by the parking light relay. It looks a little corroded and the clear coat is peeling up along with part of the green board. It looks like the circuit is broken. I will try and post pictures of the board.
