Rear tire cupping?
Old Nov 12, 2011 | 04:07 PM
c_munkey's Avatar
c_munkey
Default Rear tire cupping?
Hey guys got an issue for yall. My passenger rear tire is cupping on the inside, any ideas? I have recently replaced the shocks with rancho 5ks and replaced the u-joints. The tires were replaced about 5000 miles ago due to cupping. Im not sure what it could be. Its a 06 1500 4x2.
Old Nov 12, 2011 | 07:58 PM
lxman1's Avatar
lxman1
Site Moderator
Might have a 4-wheel alignment done to make sure the tires are running straight.
Old Nov 12, 2011 | 08:59 PM
HammerZ71's Avatar
HammerZ71
First of all, make sure you are calling your uneven tire wear the right thing. I often see guys call any type of uneven wear "cupping".
Cups are actually scalloped dips appearing around the edge of the tread on one side or the other. If you are experiencing true cupping, it's ALWAYS caused by a worn suspension component and a wheel alignment alone will seldom cure the problem. Any worn component that connects the wheel to your truck (ball joint, wheel bearing, shock absorber, springs, bushings, etc.) can cause this condition.
Now if you simply have one side of the tire wearing faster than the other, then it's NOT cupping and it's probably being caused by improper camber, which causes the wheel to lean either too far to the inside or the outside. In this case, an alignment will probably fix the condition...
Old Nov 12, 2011 | 09:18 PM
LieutenantDan's Avatar
LieutenantDan
Correct me if I'm wrong, but cupping is also caused by lack of tire rotation, correct? Although at 5,000 miles on the new tires, that's not the case. I would make sure that you don't have excessive play on that wheel. Unless I'm mistaken, and alignment won't do anything for a solid rear axle.
Old Nov 12, 2011 | 09:32 PM
Caseys-dodge's Avatar
Caseys-dodge
Hey LT, well it's true that there's not much than can be done for an alignment on the rear axle, but they should be able to at least make sure that the wheels are mounted perfectly straight. When I used to get my alignments done at pepboys (I know Hammer, I know!) they would also mount the sensor things on the rear wheels just to check the angles.
C Munkey, this page here has a few pics showing the different types of tire wear. http://www.aa1car.com/library/tire_wear.htm Keep us posted.
Old Nov 12, 2011 | 11:54 PM
Plainbroke's Avatar
Plainbroke
Wow sounds like a bent rear housing.. Let us know when you figure it out PLEASE!
Old Nov 13, 2011 | 07:04 AM
Lifttruck's Avatar
Lifttruck
Originally Posted by plainbroke
wow sounds like a bent rear housing.. Let us know when you figure it out please!
bingo!!!
Old Nov 13, 2011 | 06:41 PM
c_munkey's Avatar
c_munkey
Thanks everybody! I knew what cupping is, but its still good info. I am going to take it to a shop and let them look into it. I have been chasing things all over this truck and I am getting tired lol. Hopefully it wont be a bent housing, but I will let everyone know. I just fixed the front end shake now I have to deal with the rear.
Old Nov 14, 2011 | 04:02 PM
c_munkey's Avatar
c_munkey
Well took it to a shop and they said it was the tires. The tires were used and just put on a little while ago. Guess its time to suck it up and buy new tires. Everything I had replaced is what they would have done to fix the issue.
Old Nov 14, 2011 | 08:14 PM
LieutenantDan
Didn't you put the tires on 5,000 miles ago? Or are you saying you put used tires on?
