Coming up on 30K, you know what that means
Old Nov 24, 2011 | 05:24 PM
08HEMI1500's Avatar
08HEMI1500
Default Coming up on 30K, you know what that means
Time for spark plugs! Yay! Well anyways I plan on tackling this job myself and after reading some I know that the back plugs are a b****, I need the plug socket attachment and I'm staying with the coppers. But I have read once or twice about new plug wires as well? What's the deal with that? Do I really need them (or is it worth it). I like Hammer's motto of "make every repair a mod" so if I can get better ones then I will. And also how do I go about changing the wires? Sorry for the 20 questions but I wanna get this right.
P.S. I'm not doing this until December when I'm out of school for winter break.
Old Nov 24, 2011 | 05:27 PM
MikeHTally's Avatar
MikeHTally
You have no plug wires. IMO, it isn't necessary to change the plugs that soon. When I did my C at 49K, the gaps weren't very bad (.050 to .053). I used NGK 5306s in both Hemis.
Old Nov 24, 2011 | 09:20 PM
socket462's Avatar
socket462
Yep-- he's right-- the later models 5.7's (2006 and up?) don't have wires. The coil packs are right on top of the plugs. Yes, they are a b*tch. Be ready to remove each front tire and wheel liner to get to the firewall side ones. 30k is simply a recommendation- I went 43k before changing mine with no problems. I used Champion coppers as well- I don't see any need to spend any more on gimmicky plugs myself. Remember to buy 16 of them when you do buy them.
You could simply pull one from one of the front cylinders and inspect it to see if you should replace them yet or not.
Old Nov 25, 2011 | 02:52 PM
adventurer's Avatar
adventurer
Also Don't forget to clean or change the PCV valve and to clean the throttle body , Good luck
Old Nov 26, 2011 | 04:54 AM
08HEMI1500's Avatar
08HEMI1500
I cleaned the throttle body when I did my intake but I'm sure it wouldn't hurt to do it again and I'll look into the PCV valve since I didn't know about that. Thanks
Old Nov 26, 2011 | 12:21 PM
Fav40's Avatar
Fav40
I did my plugs at 32k miles and it seemed like a waste, imo. I have a few friends with Hemi's in various trucks and all have done theirs later.
If you feel better, do it ! It can wait tho
