tail lights, what do you think?
Old Jul 30, 2005 | 03:08 PM
magnum v8's Avatar
magnum v8
Default tail lights, what do you think?
I found these tail lights on eBay. I think they look awesome, but wonder if they are truly street legal. Also, I don't see any red reflector. I doubt it's legal to have clear brake lights. What is your opinion?
Tail Lights
John
Old Jul 30, 2005 | 03:13 PM
Scratch's Avatar
Scratch
Default RE: tail lights, what do you think?
I'm not overly fond of the Altezza style lights. None of the lights will be clear. You are supposed to install the chromed red and/or amber light bulbs.
Old Jul 30, 2005 | 03:15 PM
magnum v8's Avatar
magnum v8
So the entire unit will still be clear, until you apply the brake or turn your lights on? Are the red bulbs easy to find or special order?
John
Old Jul 30, 2005 | 03:20 PM
05_Ram's Avatar
05_Ram
Keep in mind, on very clear lenses, once you put red or amber bulbs in, that reflector tends to also look red or amber even when the buls are not lit. Unless you went with LED's that appeared clear until lit. And then you may have to change your flasher to one designed to drive smaller loads.
Old Jul 30, 2005 | 03:21 PM
magnum v8's Avatar
magnum v8
So basically this tail light set is a lot more work than plug and play, right?
John
Old Jul 30, 2005 | 03:25 PM
05_Ram's Avatar
05_Ram
Well, it's not truly plug and play. But, then again, the red and amber lights may be readily available, I don't know. I was just pointing out that when actually installed (with bulbs) they won't appear quite as white and clear as the photo shows. If you like em, get em. Just remember they aren't legal with clear bulbs.
Old Jul 30, 2005 | 06:03 PM
Scratch's Avatar
Scratch
I have seen them in Auto Zone and online at some custom car lighting stores. Your lenses will still appear to be clear because the bulbs have a chrome-like finish on them, but will shine red or amber when the brakes or turn indicators are applied.
Click here to see what I'm refering to.
Do some looking around, you will find a set.
Old Jul 30, 2005 | 06:47 PM
osteodoc08's Avatar
osteodoc08
They are legal as long as you use colored bulbs. Order them and while they are being shipped, find some bulbs locally that have the chromed type finish that light up the appropriate color. LED can be used, but you'll have to wire in a resistor. Pretty much just recapping what Scratch said.
Old Jul 30, 2005 | 10:05 PM
GeeWillikers's Avatar
GeeWillikers
Horrible. They would look good on the back of a Honda right underneath the giant aluminum wing.
Altezzas make baby Jesus cry...
Old Jul 30, 2005 | 10:13 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
I like them. They'll look good if you have all the chrome accessories. Other than that, they are sweet.
