blinker issue
My grandfather recently bought a 2002 1500 quad cab and when he turns on his left blinker the "lamp out" light comes on. It's is the rear left blinker that is not working, but the same bulb works fine when we hit the brakes or turn on the lights (I forgot which it is) So that bulb doesn't work only when it need to blink, I switched the bulbs around and still no blinker, any ideas?
Trending Topics
Both the red bulbs in the tail lights (and also the front markers) are dual filament bulbs. So one filament will light for tail light operations, and they both light for the turn signal (or brake depending on which bulb assembly). So if you swapped the left bulb out with the bulb in the right tail light and the symptoms stayed the same on the left side it's very likely going to be the circuit board assembly in the tail light, (which is a pretty common problem) The easiest way to test it since you already have the tail light out is to use a test light or a voltage detector to check for the correct voltage at the connector plug. I'll see if I can find the pin out diagram for it....
Here ya go! You'll want to test pin #5 for the blinker voltage, a test light would be better for this because the voltage will constantly be switching between 12volts and 0, some digital multimeters take too long to update when it's changing all the time (my cheap one does anyways)
Yup, I'm pretty sure we all have an 'electronic flasher' which is built in to the instrument cluster.
