miss or shudder from engine???
Old Nov 29, 2011 | 10:48 PM
Poorman's Avatar
Poorman
Smile miss or shudder from engine???
hey yall, my 08 has a miss or shudder or sputter whatever you want to call it, its only there when i level off the speed and just barely keep my foot on the gas, then it shudders or whatever you call it, what is it? its been like this since i got it 2 weeks ago. i changed the gas to better gas and ran injector cleaner through it but its still there, it idles smooth as can be and runs down the road good except the shudder,,,
thanks
Old Nov 29, 2011 | 11:01 PM
diesel 2010's Avatar
diesel 2010
check the tps sensor, i ran sea foam through my 4.7l that had a similar problem and replace my tps sensor and it runs great now. not sure if thats your problem but fixed mine.
Old Nov 30, 2011 | 10:18 AM
Poorman's Avatar
Poorman
thanks il have to check into that.
Old Nov 30, 2011 | 06:18 PM
lxman1's Avatar
lxman1
Site Moderator
His is drive by wire so it isn't the same as older 4.7's. How many miles? it needs top plugs @ 30K miles.
Old Dec 1, 2011 | 12:13 AM
Poorman's Avatar
Poorman
drive by wire ???
i have 25000 on mine
Old Dec 1, 2011 | 04:20 PM
Scott06HEMI's Avatar
Scott06HEMI
Originally Posted by Poorman
... what is it? its been like this since i got it 2 weeks ago. i changed th...
thanks
If you just got it 2 weeks ago and if this is your first Ram after the 2004/2005 model it could be your MDS kicking in (I'm pretty sure it stands for Multi Displacement System). It is a fuel saver feature that allows the engine to shut off 4 of the 8 cylinders.
Old Dec 2, 2011 | 09:16 AM
Poorman's Avatar
Poorman
yes its my first ram in forever. how do i tell if it has MDS ???? thanks
Old Dec 5, 2011 | 10:01 AM
Scott06HEMI
Well my 2006 has MDS but it may be limited to the HEMIs only and I just saw you have the 4.7 so maybe my first post isn't worth crap. I just looked up online and it seems that is was only on the HEMIs in 06 but they might have changed it in 08. Maybe someone can chime in and give some more info.
Old Dec 6, 2011 | 11:25 AM
DodgeCares's Avatar
DodgeCares
Poorman,
If you PM (private message) me the VIN I will send you a build sheet with all your options and look for any service bulletins that may apply to your symptoms.
