Trans Temp Gauge
Old Nov 30, 2011 | 06:08 PM
04Silver Ram's Avatar
04Silver Ram
Default Trans Temp Gauge
I have an 04 1500 with a Hemi. I want to put the temp sending unit in the test port of the transmission. I crawled under it tonight and there are 2 ports that are plugged off. Which one do i use?
Thanks
Old Nov 30, 2011 | 06:29 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im not sure since my Trinity reads trans temps through my PCM but we have a complete DIY on here somewhere
Welcome to the site
Old Nov 30, 2011 | 06:59 PM
04Silver Ram
I looked in that section. The post i found, the pics were gone and he just said use test port 3. Mine are not labeled so idk which one it is. I PM'd him, just wanted to see if anyone had an iea which one it is.
Old Nov 30, 2011 | 08:01 PM
HammerZ71's Avatar
HammerZ71
I did one when I installed mine, but I know the pics were lost when we did the software conversion. I know I lost my pics when I lost the HDD on my old laptop. I may have them on an SD card around here somewhere. If I can't find them I'll crawl under my truck and snap a pic...
Old Nov 30, 2011 | 08:57 PM
04Silver Ram
Thanks man that would be very helpful.
Old Dec 2, 2011 | 10:22 AM
04Silver Ram
did you get a chance to look which port you used?
Old Dec 2, 2011 | 05:22 PM
HammerZ71's Avatar
HammerZ71
Sorry, my Grand Cherokee's radiator decided to blow up on me and I forgot all about it. Here is a pic I found in an older post in this section that shows the location...
Now I did not use the test port, I used a "T" fitting on the trans cooler out line. Either way will work fine...
Old Dec 2, 2011 | 05:44 PM
04Silver Ram
Thanks alot man
Old Dec 2, 2011 | 06:56 PM
robinsonfam1's Avatar
robinsonfam1
Off topic:
UGGH...grand.....jsut swapped mine for the RAM. had over 200K on 98 ZJ. all sorts of tweeked. it croaked all at once. it was time....."The Black Pearl"
rough lookin but good lookin too. Always got me home.....Hence the name.
Old Dec 2, 2011 | 07:30 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by robinsonfam1
Off topic:
Yeah, cheap a$$, stupid plastic tub radiator! I have a buddy with a '99 WJ, 230k miles on it, he's on radiator number four but the drive train is still solid as hell. I've had it over 5 years now, most of it completely trouble free, but now that it's hit 100k miles I'm getting all the common sh*t hitting me all at once. I've done the blend doors, window regulator, had a caliper seize and now the radiator and while I'm replacing it, I have a broken manifold bolt to deal with. I'm just waiting for the heater core to decide to take a sh*t once I replace the radiator...
