HELP Please.. 02 1500 4.7 issues
Old Dec 3, 2011 | 01:00 PM
ricks02dodgeram's Avatar
ricks02dodgeram
New Member
Default HELP Please.. 02 1500 4.7 issues
I have a 2002 dodge ram 1500 4.7. Up until last week it was running fine, I put gas in it drove a couple of miles then shut the truck off when I stopped for 30 minutes or so... When I started the truck back up it was running horridly. It is idling VERY rough, stalling out and jerking about, it is burning tons of gas too...
I thought perhaps it was bad gas, so I drained the gas and put premium fuel in it. No change.... These are the things I have done to try to figure this thing out... I am at my wits end, and the wife wants her truck back... I need some ideas from someone else at this point...
Changed out:
IAC
Crankshaft Position Sensor
Camshaft Position Sensor
All new spark plugs
Did a compression check and everything checked out fine
Map sensor
If I have my foot in the gas, she runs alot better, but whenever I go to stop at a light, I have to keep my foot in the gas and the break, or else she dies...
I am at my wits end and don't know what else to do... The only code that is being thrown is p0352... So I changed that coil .... Still throwing that code, and running like garbage...
Anyone out there have any ideas???
Thanks in advance!
Old Dec 3, 2011 | 02:23 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
EGR valve? Mine wasn't as sudden, or as drastic, but it sounds kind of like the symptoms when the EGR valve went out in my '05. Just a WAG from my own experience. That's about the extent of my knowledge on that, though.
Old Dec 3, 2011 | 02:29 PM
ricks02dodgeram
New Member
Glad you mentioned that, cause I forgot to mention that the EGR had been changed as well.... Like I said, I am stumped.... The truck really has me scratching my head right now... I called my mechanic and told him of the problem and told him everything that I had done to try to trouble shoot it so far, and he mentioned the crankshaft sensor... Changed it out, and still runs like garbage... Thanks for the reply!
ANYONE ELSE?!?!?!
Old Dec 3, 2011 | 07:57 PM
boxerguy84's Avatar
boxerguy84
Maybe it's the fuel filter and/or pump?
Old Dec 3, 2011 | 10:19 PM
big guy's Avatar
big guy
I think your compression test would of found this ? But I have read more than one thread. Where the 4.7 would throw a rocker arm. Causing very rough idles, lack of power etc. Might want to pull the valve covers to look see. Just puting that out there.
Wish I had more to add.
Good Luck
Old Dec 23, 2011 | 10:08 PM
timekop's Avatar
timekop
Have you cleaned the throttle body and air intake? It may be dirty.
Old Dec 23, 2011 | 10:11 PM
timekop's Avatar
timekop
Have you cleaned the air intake and/or throttle body? I've had this before. Just used some brake cleaner and wiped it out really well and the problem was solved.
Old Dec 24, 2011 | 01:32 PM
outcast's Avatar
outcast
dont use brake cleaner use carb cleaner thats wat its for, brake cleaner is to harsh can eat at plastic sensors
Old Dec 25, 2011 | 11:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
4.7s have more than a few threads here where they sometimes throw rockers under the valve covers. Not having a valve open or close would make it run rough also
