PA Body Lift
Old Dec 8, 2011 | 06:17 PM
T-Muns's Avatar
T-Muns
Originally Posted by jms2291
Alright I might be getting screwed te local shop told me that I need new brake lines and to adjust my steering...does this sound right? The kit doesn't mention it in the directions. I need help! If any of y'all ga boys have a spare Saturday il gladly pay your time and supply your beverage...lol
The kit should come with a steering shaft extension, but that's the only thing they need to "adjust" for steering. I didn't think you had to do anything with brake lines.
Old Dec 8, 2011 | 06:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
agreed. I took my lines loose so nothing got pulled then the body was lifted but that was all. As said above, steering shaft comes with kit
Old Dec 8, 2011 | 06:28 PM
HammerZ71's Avatar
HammerZ71
I had to use brake extension lines on my 2nd Gen, but they came with the kit & the instructions showed them, if you didn't get them you don't need them.
Old Dec 10, 2011 | 10:28 AM
jms2291's Avatar
jms2291
Ok final concern..I'm assuming from looking at the kit my brush guard as it sits now will not fit anymore...will I need to fab up some new brackets or will the brackets provided fit to the new bumper mounts?
Old Dec 10, 2011 | 10:31 AM
HammerZ71's Avatar
HammerZ71
On my buddy's Z71 we had to fab up brackets that raised the grill guard up the 3" of the lift. As stated, with a winch mount on my grill guard that's the reason I don't have a body lift. If it was just the grill guard, no problem, but a winch mount that needs to support 100% of the weight of the truck, I'm leary of fabbing up mounts...
Old Dec 11, 2011 | 07:07 PM
03gsxr's Avatar
03gsxr
My brush guard lined up perfect after my 3" body lift but then again my guard bolts up to the bumper brackets that i had to move up via PA lift instruction so my guess is if your guard bolt to your bumper brackets it should line up (mine did) only problem I had doing mine was the steering extender that came with the kit the bolt to tighten it up stripped on me so I just drilled the hole a little bigger and ran a bolt lock washer and nut on it took me and a buddy all day was or first time doing it and after following all the instructions we could have skipped alot of them I have a 02 and I didn't have to loosen the brake line ,body ground or gas line from the bed of the truck and the link for my 4x4 i didnt have to weld the spacer in it I just adjusted mine Good Luck and have fun it will be well worth it when its done mine looks so much better lifted
