03 ram 4x4 knocking in rear end HELP
Old Dec 9, 2011 | 06:35 PM
knockingdodge's Avatar
knockingdodge
Exclamation 03 ram 4x4 knocking in rear end HELP
I have a 2003 dodge ram 5.9 gas and when i go in reverse i hear a loud knocking noise. if i do it and press the parking brake while moving it stops, then as soon as i let it go it starts again. Now the truck is starting to do it in drive as well. i thought it was the parking brake so i took it apart and there is nothing wrong with it. the u-joints feel tight but how would i know if they are bad? please let me know any suggestions.
Old Dec 9, 2011 | 09:00 PM
lxman1's Avatar
lxman1
Site Moderator
Try jacking up the truck and have someone put it in gear and see if you can hear where it is coming from.
Old Dec 9, 2011 | 11:29 PM
knockingdodge
it wont make the noise. i tried that. its only when on the ground.
Old Dec 10, 2011 | 12:01 AM
lxman1's Avatar
lxman1
Site Moderator
I would guess a possible axle bearing or pinion bearing.
Old Dec 10, 2011 | 12:45 PM
knockingdodge
ok, thank you for trying to help. i will look into those and if they arent too expensive, i'll just go ahead and change them.
Old Dec 10, 2011 | 02:05 PM
lxman1's Avatar
lxman1
Site Moderator
The shouldn't be too pricey.
Old Dec 10, 2011 | 08:56 PM
knockingdodge
They arent, but if anyone else sees this post and has any ideas of what it could be then please feel free to throw ideas out. thank you. also if you know where to get a diagram that shows the names of all the parts in the rear end, that would be great.
