Halo Fogs wiring
Old Dec 10, 2011 | 07:06 AM
Gorhad's Avatar
Gorhad
Default Halo Fogs wiring
Hi all
I have a 2004 Ram 1500 SLT.
The truck is fully wired for fog lights, so I went a purchased the light switch plate with the pull out facility for fog lights.
Yesterday arrived my fog lights (Halo projector).
My question is I assume I wire the center dome light up to the fog light circuit, but what about the halo ring? I read somewhere that that has to be wired into the day running light.
Thanks in advance
Old Dec 10, 2011 | 08:03 PM
CaliDodgeRam's Avatar
CaliDodgeRam
I know for the halos on my truck, which are in my headlights though they are taped into the running lights. Where did you get the fog halos?
Old Dec 11, 2011 | 08:02 AM
Gorhad's Avatar
Gorhad
I got them off ebay from a seller called rambowtech
Old Dec 12, 2011 | 10:14 AM
Gorhad's Avatar
Gorhad
So is it OK to just splice directly into the running lights without relays or fuses
Old Dec 13, 2011 | 10:44 PM
Caseys-dodge's Avatar
Caseys-dodge
If they are LED halos, then it shouldn't be much of a problem to just tap into the running lights since the additional amp draw is next to nothing. If they are the CCFL halos, you'll have to find out how much amperage or wattage they will draw.
Old Dec 14, 2011 | 05:37 AM
Gorhad's Avatar
Gorhad
Thanks they are LED's
Old Dec 14, 2011 | 07:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Putting projector fogs in the truck defeats the purpose of having fogs that should give a flooding type light.
You should have added OEM HID projectors in the headlights instead
Old Dec 14, 2011 | 07:26 PM
Gorhad's Avatar
Gorhad
Yes i figured that now they are crappy led ones oh well after christmas i will get some oem style ones
