REC radio unlock code??
Ive got an 06 ram with the Rec radio in it. I had the battery unhooked and when I hooked the battery back up its asking me for a 4 diget code to unlock the radio/cd etc. Im the second owner of this truck and havent a clue what the code would be...any thoughts. The dealer was of no use to me on this either, told me it was the last 4 digets on my VIN but the vin has an 8 & 9 in it and the radio numbers only go to 6.
Some of the '05 REC units used in the US came with this, but the "feature" was quickly removed, I believe with software updates. Also, the European and Canadian models used this "feature" for all of their '05+ REC units, but don't quote me on that, as I'm not sure on all of the years. It is a 4 digit code consisting of the numbers 1-6 and it would have come with the truck's factory paperwork. I do not know if it can be provided afterwards, but I would assume with your VIN and the radio serial or hardware number the dealer may be able to help. Best of luck to you.
Kev,
PM me the VIN and I can send you a build sheet. Perhaps that has some numbers on it.
